Not reciving calls from witheld numbers
Ulllass59
Valued Contributor
Valued Contributor
Hi
Inam getting anoyyed uf some one rings me with a witheld number I do not receive  their calls at all. I then get a text sometimes from them or an email saying we tried to callyou. Some times  get a missed call with just private number too. Why is this please. Missed a few important calls through this problem
@Ulllass59  on your device have you blocked withheld numbers?
10 REPLIES 10
Ulllass59
Valued Contributor
Valued Contributor
Nope ni dea how u do that.
James_B
EE Community Manager
What type of phone are you using @Ulllass59?
Ulllass59
Valued Contributor
Valued Contributor
Samsung galaxy  S21 FE
Jon_K
Former EE Employee
Thanks @Ulllass59
Can you go to Phone, then Settings, then Block Numbers, and see if unknown numbers are blocked?
Jon
Ulllass59
Valued Contributor
Valued Contributor
Hi
Just had a look no blocked numbers.
Jon_K
Former EE Employee
We aren't looking for specific blocked numbers, @Ulllass59, can you see if no caller ID numbers or unknown numbers are blocked?
Jon
Ulllass59
Valued Contributor
Valued Contributor
Hi
There's nothing on the list it's blank.
Jon_K
Former EE Employee
It's not a list you're looking for, @Ulllass59.
Can you see a toggle option for blocking certain calls?
Jon
