27-03-2024 08:28 AM - edited 27-03-2024 08:29 AM
I have both the Roam Abroad Pass and World Talk and Text. During my last trip to the USA I was unable to receive text messages. All data services worked fine. Given how common 2FA is now this was a bit of a problem. Anything I can do to check before my next visit? Thanks
27-03-2024 10:34 AM
Hi @_Finn
Welcome to the community.
If you text ROAMING to 150, does it tell you that roaming is activated?
27-03-2024 11:06 AM
That's a good point. I receive a welcome to USA / Canada / Etc when I land and I can use data no problem so I assume(d) that roaming is on.
27-03-2024 11:19 AM
Yes, that's right, @_Finn
Best advice I can give, if that incoming message issue happens again is to manually select a different network. Maybe play around with the network mode too, just to cover all bases.
27-03-2024 11:26 AM
Thanks Chris, I'll give that a go on my next trip.
