Not receiving messages from Uzbekistan
aaziztu
Hi, I’m not receiving messages and calls, I’m in Uzbekistan, please help me
@aaziztu : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
