on 02-09-2024 02:27 PM
I am in Greece. I am no longer receiving calls to m iPhone 12. Did not have a problem receiving calls to at least last Wednesday. Only realised when someone called my husband as couldn’t get me.
Tried the fixes I can think of. Restarting, airplane on/off and manually changing network but nothing has worked. I can still receive texts but no calls.
EE PLEASE HELP!
02-09-2024 02:15 PM - edited 02-09-2024 02:19 PM
Hi Barkley1,
Have you had any luck? I am in a similar position as you in Greece. Tried all the fixes you have tried including trying to manually change the network too. I can receive texts but no calls now. Only realised when someone called my husband. I did receive calls up until last Wednesday though.
on 02-09-2024 02:45 PM
Try a 2way SIM-swap, manually connecting to a known working network.
Put your SIM in your husband's phone - what result?
Put your husband's SIM in your phone - what result?
on 03-09-2024 09:16 AM
Hi @JackieR24,
Welcome to the Community!
We want your travels to be trouble free, so I'd love to help you get this sorted. Are you able to make calls, or send texts, or are you also having trouble doing this?
Rach
on 03-09-2024 09:36 AM
Hi, yes I can send and receive texts. I can call but cannot receive incoming calls..
on 03-09-2024 02:52 PM
@JackieR24 Have you been able to test your SIM card in an alternative phone at all?
You can also check if you have blocked all incoming calls in the phone settings.
Is it all incoming calls which are blocked?
Ali
