No signal
Uz28
No signal in Dubai can anyone help?
Northerner
Hi @Uz28
If you haven't activated roaming then you'll need to download Skype and use the number in my signature to contact EE tomorrow (UK office hours).
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
