on 25-07-2022 02:09 AM
Hoping someone can help resolve this
I purchased the "roam further" add on in the UK, but since arriving in the US have no connection at all (calls or data). Things I've tried to fix this:
- turned the phone off and on again
- cleaned the SIM card
- turned roaming off and on again on my phone and in my EE settings
- tried to manually switch network (says no networks found)
I can't call EE to fix this. Any suggestions!?
Solved! Go to Solution.
on 25-07-2022 01:36 PM
Hi Leanne
I'm on a pixel 4a. I just tried the SIM card in my husband's pixel 5 and that seems to have fixed it. It found signal on his phone and is now working for me too!
Sophie
on 25-07-2022 03:06 AM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
on 25-07-2022 01:07 PM
Hi!
I'm on a pay monthly contract and roaming was already enabled (worked in Italy the weekend before).
I've tried all those things you have suggested (reboots, all settings enabled) as per my original message. Any thoughts on what to do next please? I currently can't use my phone at all so can't navigate or get around the city!!
on 25-07-2022 01:10 PM
Hi @Sophiedent
Thanks for confirming everything you have tried.
Which device are you using?
Do you have any other phone you could try the SIM card in to see if this shows signal?
Leanne 🙂
Hi Leanne
Sophie
on 25-07-2022 02:00 PM
