on 16-06-2024 09:47 PM
Hi I am in Portugal but I have no service. I have contacted customer service prior to this trip to ask if roaming could be set up they said it would set up and nothing has been done. I need help
on 16-06-2024 10:39 PM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
