No network out of UK
Marta85
I’m on vacation in Spain and I have no network. When I arrived to Spain I received a message saying that I’m able to use EE but it works during 2 days. I already pay my monthly and I can’t use it. I need a solution as soon as possible.
@Marta85 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
