on 27-07-2022 03:29 PM
I’m roaming in Dominican Republic and I’m connected to 4G with strong signal but I am not getting data. I have the roaming abroad pass.
Solved! Go to Solution.
on 28-07-2022 02:26 AM
The Roam Abroad Pass is not valid for the Dominican Republic.
on 27-07-2022 03:45 PM
@Bandejapaisa : Can you make calls & texts?
Did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
on 28-07-2022 01:43 AM
Hey there,
Which pass do you have activated and is it valid for use in the Dominican Republic?
on 28-07-2022 10:30 AM
That’s right. After speaking with customer service, it’s not valid for Dominican Republic. In fact, it’s fairly useless for most of the world
The biggest crime is the offering of 10MB for £10 by EE when you arrive, or up to 50MB for £50. This is insanely expensive for data you will use up potentially in minutes if you’re not careful and know what you’re doing.
I got a local Dominican SIM for £10 for 23GB (that’s around 23,000MB) I turned off mobile data for all apps apart from safari and I was checking the weather too and Uber. I turned off background updates etc. And I still used 60MB of data.
How many people are being ripped off and really unaware
on 28-07-2022 10:34 AM
If you don't count the EU & the USA as part of the world!
on 28-07-2022 11:57 AM
I said it was fairly useless for most of the world. Which is accurate. It doesn’t cover several whole continents.
