28-12-2021 03:53 PM
Hello,
I am currently roaming in Canada, I have an EE iPhone SE as a company issue phone, however, I cannot get mobile data to work. Yes, Data Roaming is enabled and it shows 3G for the service provider on full bars. I can make calls, but not receive them and WiFi works fine for data. I have previously roamed and had data working fine.
I've tried all of the usual things, such as changing service providers from automatic. Rebooted my phone, taken the SIM out and performed a Network Setting reset, so I can't think what else I can do at my end..
Having tried to call EE on the number that was sent to me on the SMS that I received on arrival in Canada and the number on the EE website, but both these say my number in invalid, which could be because its a corporate phone...
The error I receive is "PDP authentication failure".
One more thing, the rest of my group have Vodafone contracts and they are all working fine, so it's not a local Network issue!
What should I do next?
28-12-2021 04:14 PM
Hi @chrisit ,
Has your company applied a roaming pass such as the "Travel Data" pass? https://business.ee.co.uk/help/network-and-coverage/roaming/
Different UK networks may be better or worse for international travel and you may review these at https://kenstechtips.com/index.php/using-your-mobile-phone-abroad
A you sure that you have a data allowance for use in Canada and that this allowance is not zero?
28-12-2021 04:59 PM
@chrisit : Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
28-12-2021 05:04 PM
With my job, I'd expect to be travelling to Canada as well as most of the rest of the world when we are not locked down, so I'd hope we are not restricted... It's a new contract (well 18months, but we all know about travel during that time).
I would still expect to be able to use data, just be charged for it.... The problem is that I have no way of contacting EE, when i go through all of their published numbers it tells me that my EE number is not recognised, which I guess is as it's on a corporate contract...
All in all, pretty shocking that you can't get through to understand the issue...
28-12-2021 05:07 PM
Sorry that number does not work...
28-12-2021 05:20 PM
Hi @chrisit ,
The "by the book" approach would be to inform a relevant colleague, responsible for managing the EE contract, of the situation and await a resolution, in case you are not able or authorized to make chances to the contract yourself.
Even if you are able and authorized to made changes, it may not be a good use of company time.
28-12-2021 09:11 PM
I think a previous poster has hit the nail on the head here.
So your roaming is working hence you being able to pick up a network.
EE are set up to not allow customers to run up massive data roaming bills and instead don't allow data to be used abroad without an add on. This will explain why your data is coming up as 3G and isn't working.
You need your company contact to add the business equivalent of Roam Further to allow you to access the data services.
If your phone is working by the way then you should be able to call customer service from your phone (but again, might need to be your company who sort it).
