No Calls or Texts Abroad
sapphire_98
I am currently in the USA on holiday. I added the Roam Abroad Pass before I came. I can use data while here but calls and texts aren't working.
I have tried texting ROAMING to 150 but because I have no texts it won't send.
I have tried to go to my account and activate like other posts say but I can't see that anything is turned off.
Schockwave
@sapphire_98 , if you are on a monthly contract, you will have to ring customer service to activate this, as roaming needs to be activated, roam abroad pass has nothing to do with having roaming activated, they are two different things.
If you have something like Skype, you can ring customer service for free on the number in my signature.
Schockwave
