18-07-2024 01:04 PM
@ Hi can anyone help please my phone won't work in Spain I have set data roaming
18-07-2024 01:13 PM - edited 18-07-2024 01:19 PM
@Braderz1 : Any data roaming setting on your phone won't have anything do with it if you haven't activated roaming on your a/c.
Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
18-07-2024 01:16 PM
Data roaming simply means allowing the use of mobile data whilst roaming - it's useless without having roaming enabled in the first place.
