My mobile data is not working
Idkay_
Hi everyone,
I need help.
I’ve been unable to use my mobile data for a week now. I woke up one morning and it just says it’s not activated. I’ve done everything but it’s not working. When I put it on instead of 5G it’s showing EDGE and saying it’s not activated. I can’t send texts to 150. Making calls seem to be very difficult even receiving.
10 REPLIES 10
Idkay_
Same issue I’m facing right now have you found a solution?
EDGE means your phone is on 2G.
Try toggling flight mode and also restarting your phone in the first instance.
It’s not working
I’ve done that almost every day I don’t know what else to do
Leanne_T
Hi @Idkay_
Thanks for coming back to the community 🙂
Is this happening in more than one area?
What device are you using?
Yes everywhere I have gone
I’m using an iPhone 15
Leanne_T
Thanks @Idkay_
Could you try going into Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings, this will restart the iPhone and remove any saved WiFi passwords.
Does the same happen after trying this?
It’s still the same
Sent from my iPhone
Leanne_T
Thanks for trying @Idkay_
Are you able to try the SIM card in another phone to see if the issue follows the SIM?
Leanne 🙂
Do you know anyone else locally who uses EE - do they have similar problems? I suspect they won't, but worth checking.
Otherwise, try a 2way SIM-swap, which any EE retail store can assist with if necessary.
Put your non-working SIM in a working phone - what result?
Put a working SIM in your non-working phone - what result?
