My Mobile
Idrisali
I'm outside the UK and mobile number remains either unregistered or unavailable for use- either calling back to UK or somewhere else- The roaming of my phone is on and still I can't even call EE on 150 or any other phone numbers enlisted EE website- Also, I can't receive or send any text message on my UK number
I will highly appreciate if I can get any assistant or support in this regards,
Idris
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
