09-10-2021 12:12 PM
My Motorola G7i power cancels outgoing unanswered calls after a few seconds. It rings mobiles without any problems. How can I get it to ring out longer?
09-10-2021 01:33 PM
Hi @settlerman
Is this when you call a landline?
Does this happen with more than one number?
Thanks 🙂
09-10-2021 02:53 PM
Hi. Yes it only happens on landlines. So far it’s only one landline. I’ve used another EE phone and called the same landline and it works perfectly.
09-10-2021 03:03 PM
Hi @settlerman
Thanks for coming back to me.
Are you able to try the SIM card in another phone to see if the same happens?
Thanks 🙂
09-10-2021 04:02 PM
I’ve tried the SIM in another phone and it works ok. Put SIM back in original phone and it cuts out after 10sec as before.
09-10-2021 06:00 PM
Hi @settlerman
Can you try deleting any call history to this number from your phone.
Also, if this is a contact saved to the phone, can you delete this and try and call the number again, does this ring for longer?
Leanne 🙂
09-10-2021 07:07 PM
Have deleted call history and contact. Redialled and still cuts off after 10secs on landline only.
10-10-2021 07:55 AM
Thanks for trying @settlerman
The next step would be to back up all your data and factory reset the phone.
Could you try this and let me know how it goes?
Leanne 🙂
13-10-2021 06:08 PM
Still no joy. I’m using the phone on Wi-Fi calling and everything is fine. Looks like that’s what I’ll have to do.
14-10-2021 07:49 AM
Hi @settlerman
Did you try the factory reset?
Can you call landlines when you are in other areas?
Thanks 🙂
