Mobile network in Italy
Mesut
Like Erica_e, I've been in Italy for 8 days, but since yesterday (5/2) there's been no mobile network that my wife and I (both EE) have been able to access.
11 REPLIES 11
Christopher_G
Hi @Mesut
Could you try manually connecting to the Iliad network? If you're within coverage range, you should get a connection through that operator.
Hi, That seems to have worked. Many thanks.
Any idea about what the problem is on the 'auto-select' network setting?
Christopher_G
I'm not sure what the problem is, but it's being looked into, @Mesut.
Glad you've managed to get connected.
Kaz5829
My husband and me are both EE and have always been connected to the TIM network whilst in Italy( south Puglia). This morning I noticed my network had changed from TIM to Ilead. Is there a problem with TIM?
Christopher_G
Hi @Kaz5829
We're aware that a small number of users have had some connectivity problems. Have you been able to stay connected with Iliad?
Ana44
Hi Erika, same for me. Did you find out the issue?
Hi Christopher_G,
Your suggestion did not work for me as I receive no signal from any broadband. I spend a lot of time in Italy and this is the first time that this happens to me.
can you please advise?
Yes Chris we have still been able to stay connected.
Just wondered why it had changed over and what had happened to TIM.
Thank you for your help
Sent from my iPhone
Christopher_G
Hi @Ana44
Have you tried connecting manually to both the TIM and Iliad networks?
