Just arrived in France sim does not allow connection to French services
Matthewrea
How do I enable phone to connect to Frence service providers? As sim looks like is blocked by EE, even though I have paid for EU roaming?
@Matthewrea : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
