Intermittent phone ring
Pantheman
I have just bought a Nokia X10, although it shows I have a full signal, sometimes calls go  straight to voicemail without ringing or vibrating, any ideas.
7 REPLIES 7
Christopher_G
Hi @Pantheman
Welcome to the community.
Does your phone lose signal at all? Could you check the status of the network in your area?
This would usually a suggest the incoming call was blocked or you have a "do not disturb" mode active.
Pantheman
Hi
It happens when I have a full signal, I checked the signal in my area and it was good.
Pantheman
Checked all that no luck
James_B
EE Community Manager
Hi @Pantheman,
Does it just happen with one particular number or everyone?
It just happens on my EE account
Jon_K
Former EE Employee
What do you mean on your EE Account, @Pantheman?
Does the call issue happen with all numbers or just one number?
Jon
