In Spain no mobile data
christophersewe
No mobile data in spain
@christophersewe  Are you a contact customer?  Have you enabled roaming on your account ?
@christophersewe : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
