Im in Cyprus with no network
Mlyka28
Schockwave
Hello @Mlyka28 ,
Welcome to the community,
Are you on pay as you go or contract?
If on contract, did you make sure that roaming, call abroad and premium calls are enabled? You can do this via the App or logging into your account.
If you are unable to do so, then if you have Skype, you can do this for free:
https://ee.co.uk/contact-ee/account-billing/mobile
If pay as you go, you will need to have enough credit on your account.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
