I've changed my phone number how long does it take till I can use it
F-y
Christopher_G
It should have gone through pretty quickly, @F-y. It can take up to 24 hours for a number change to go through though.
17 REPLIES 17
BrendonH
Community Hero
Community Hero
When did you request the change? Like a normal PAC migration it can take til the next working day.
BrendonH (Android Expert) Google Pixel 8 Pro Obsidian Black (Android 15)
Hi I changed it yesterday about 4pm
thanks for your reply
James_B
EE Community Manager
Hi @F-y,
Were you transferring a number from another network?
No, staying on the same network
James_B
Hi @F-y,
Did you change your phone number or your plan?
Yes
Christopher_G
Did you change just your phone number or just the plan, @F-y? Or did you change both?
Phone number
Christopher_G
