I need roaming plan activated
Raysulislam
Hi there,
I am in Bangladesh right now and I would like to activate my roaming network. My number is **************.
my email address is ***************
can you please activate my roaming as soon as possible
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
1 ACCEPTED SOLUTION
@Raysulislam : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
