on 22-09-2022 12:39 PM
on 22-09-2022 12:44 PM
Hi @lisa03.
Welcome to the community.
Are you able to check your My EE Account to see if Roaming is enabled?
Do you have a signal on the phone?
Jon
on 22-09-2022 12:52 PM
@lisa03 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
