19-03-2021 08:08 PM
I have a SIM only plan with EE. My partner has a PAYG plan with T-Mobile - owned, run and administered by EE, who get the money every time we top up and whose equipment is used by T-Mobile customers.
Texting between us is not a problem. Nor is there any difficulty if my partner calls me.
If as/when I try to call my partner, however, I am put straight through to "if you have dialled correctly, this number is not available on this network". **bleep**?
I don't understand; FAQ offers no solution; hen I've tried online contact nobody is ever available. Can anybody in the community offer a solution, or have any idea what I should do?
Many thanks
20-03-2021 07:56 AM
Hi @papaspoony.
What phones are you both using?
When was the last time you could call your partner?
Jon
20-03-2021 10:18 AM
20-03-2021 10:32 AM
Are you dialling your partner's number directly using the number keys? Or using your contacts list?
Does it make any difference?
20-03-2021 01:14 PM
20-03-2021 01:38 PM
Then the stored contact no. must be wrong. Check it! Have you replaced the initial '0' in it with '+44'?
20-03-2021 05:13 PM
20-03-2021 06:00 PM
If you've not done so already, try deleting the contacts book entry and re-creating it.
07xxx format is preferable to +447xxx format, but there shouldn't be any functional difference within the UK.
20-03-2021 06:27 PM
21-03-2021 08:36 AM
Are you able to try putting your SIM in a different phone, @papaspoony?
Just to see if you're able to make a call through the contact entry on that?
