I am in Mauritius
Ashbee8619
I am on holiday in Mauritius and I need to call England how can I do this ??
@Ashbee8619 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making & receiving calls & texts while abroad?
