on 23-07-2022 08:14 PM
Hi...I arrived ed in Croatia today and have no roaming available in my plan - how do I get a roaming pass when phone is not connected?
on 23-07-2022 08:20 PM
@ClaireGough73 is roaming enabled on your EE account? Have you also enabled call abroad and make premium rate calls ? Purchasing a add on doesn’t enable roaming. Once you have both these options enable you can purchase the roam further add on to your your allowances while there.
on 23-07-2022 08:30 PM
on 23-07-2022 09:50 PM
@ClaireGough73 , if you have Skype, there is a free number you will find, by clicking on the contact EE, the number you will find is an 0800 number where it says from the UK.
on 24-07-2022 07:33 AM
Morning @ClaireGough73
Thanks for coming here 🙂
If you have a pay monthly account can you, log into your My EE account online go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Make calls abroad from the UK > can you activate both settings?
If not, please follow the great advice from @Schockwave and the team will help you get this set up 🙂
