How to dial when roaming in the US
thusband
Valued Contributor
Valued Contributor
If I'm roaming in the US and want to make a phone call to a US phone number do I dial like I was in the UK (using the US country code) or do I simply dial the US number as 1+area code+phone number?
Thanks for any hints.
James_B
EE Community Manager
Hi @thusband,
Yes, you'll need to use the international dialling code.
Hope this helps. 🙂
James_B
Hi @thusband,
Hope this helps. 🙂
thusband
Valued Contributor
Valued Contributor
OK I thought so. Thanks!
James_B
No problem @thusband
Have a great trip. 🙂
Aren't they the same? +1 is the US country code.
thusband
Valued Contributor
Valued Contributor
Yes, good point. +1 is the US country code too.
