23-07-2024 09:31 AM
I forgot to send ROAMING to 150 before I left the UK. I can't send the text now because there is no connect now. I called CS for help. They changed my plan to which can roam and added Travel Data Pass for me, but it still showed no connect on my phone. I just need it to receive few texts. Help!
23-07-2024 10:41 AM
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
23-07-2024 10:41 AM
23-07-2024 01:18 PM
I contact CS. They changed my plan to which can roam and added Travel Data Pass for me, but it still no connect.
23-07-2024 01:19 PM
23-07-2024 01:27 PM
23-07-2024 01:50 PM
Yes.
23-07-2024 01:57 PM
If you are confident the (free) roaming facility has been enabled on your SIM, try a manual network search and attempt connections to each available operator in turn.
If this works, you can re-enable auto-selection afterwards.
23-07-2024 02:46 PM
I tried search network manually, it didn't work.
23-07-2024 02:48 PM
Do any networks show when you manually search @ToyCastle?
Katie
23-07-2024 02:52 PM
Yes, it shows few networks. Most of them are not available. China Broadnet is available, I can't connect it.
