How do I ring EE from Greece? Switches off even when Wi-Fi calling is on.
Anitaej
6 REPLIES 6
Leanne_T
Hi @Anitaej
Thanks for coming here.
WiFi calling will only work in the UK, do you have a query we can help you with on the community?
@Anitaej : What happens when you call w/out trying to use Wi-Fi Calling, which isn't supported from abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
Ok. Thanks.
Very helpful. Thank you.
_MrR_
Scholarly Contributor
If you're in Greece then you should connect to either COSMOTE or WIND.
Assuming you can connect to the network, then you should be able to call 150 from your handset.
If you're not able to connect to the network then it's an account level issue you need support with (specifically ensuring roaming is provisioned)
Anitaej
Thanks, everyone, for your advice. I’m back home in the UK now, but will bear in mind all your comments next time I’m planning to go abroad.
