How can I receive text when In iraq
Ashleyahmed2020
Hi what add on can I add so I can text and receive text when am in Iraq as I need to be able to receive my messages
Northerner
Hi @Ashleyahmed2020
Add-ons and roaming costs can be found here:
https://ee.co.uk/help/help-new/roaming-costs/countries/iraq
6 REPLIES 6
Northerner
Hi @Ashleyahmed2020
I have added adds on but it’s still saying blocked I can’t call out I really need the phone to work
Christopher_G
Hi @Ashleyahmed2020
Welcome to the community.
Are you on contract or pay as you go?
@Ashleyahmed2020 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Ashleyahmed2020
I am contract I still don’t have access to my texts and it not letting me call that number
I never said call from your phone but from Skype over WiFi.
