Hi
Maros1
Active my Roman I can't access to send text to 150  how can I do active with out text to 150 I set up all in my phone still not connect to abroad network to I received call and text please help me
Schockwave
Hello @Maros1 ,
Welcome to the community,
Are you on pay as you go or contract? Did you use your SIM card before going abroad?
It looks like it has not been set up for roaming, you can call customer service by using Skype and their free number  if you click on the contact EE you will find the number there.
James_B
EE Community Manager
Hi @Maros1,
Have you tried following the tips in EE Roaming - Help when abroad with your EE phone or device?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
