Hi there
Cheniti
Hi there,
I am in ibiza  right now and I would like to activate my roaming network. My number is
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
Posting your email address & mobile number on an internet forum is an open invitation to slammers to contact you. I'd suggest editing that out unless the site admins beat you to it.
On PAYG, roaming is auto-enabled once your phone is used in the UK first.
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
@Cheniti : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
