01-05-2025 02:07 PM
Hi, my sim card is not connecting and doesn't appear pin my phone's settings. I've removed and cleaned it but still the same. I have travelled today and throughout it is showing the same issue. There are no obvious menu options on the website to request help on this issue.
01-05-2025 05:11 PM
Hi @fongadong
Welcome to the Community.
It does sound like there could be a problem. The issue could be with your SIM card or the mobile device not being able to read SIM cards.
Are you able to test briefly place your SIM card in a different phone? This will test if the SIM card is fault.
Also try a different SIM card in your phone too.
If your SIM card is not working, you can order a replacement SIM card through the EE App, or pop into any EE store who will be able to issue a replacement SIM card straight away.
Alternatively, you can pop into any EE store with photo ID and the store guide can issue you a replacement SIM card free of charge straight away. EE Store Finder | How to find your nearest EE store | EE
Ali
01-05-2025 05:11 PM
Hi @fongadong
Ali
