Hi I’ve gone abroad and I cannot use my home
Lewmink15
@Lewmink15 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Lewmink15
I’ve gone abroad and cannot use phone you’ve told me to contact you for add ins and to call you but I can’t use my phone to contact ee
