on 14-07-2023 07:14 PM
Hi there,
im going away for 6 weeks to India. There don’t seem to be any EE packages available for that part of the world sadly.. I understand there is a travel pass which charges you daily/when you use it.
Any advice on this would be greatly appreciated
Thanks in advance
Solved! Go to Solution.
on 14-07-2023 09:00 PM
@Lotus52 Have a look at THIS to see what you can have.
Don’t forget to text ROAMING to 150 to activate roaming on your account. You need this activated in order to connect to a network as purchasing add ons doesn’t enable roaming.
on 14-07-2023 09:01 PM
@Lotus52 : As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/india.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
