04-07-2023 11:20 PM
I’ve been in the US with a Go Further/Roam Further Pass for 24 hours but it is not working at all. I’ve spent 1.5hrs on phone to 150, incl technical support but got cut off. I still have no data. Can someone please get in touch to sort this out?
07-07-2023 12:36 AM
Hi @Chris_B Yes, have tried switching to 4G and still nothing. Tried in another location earlier today. Still nothing. But the T-mobile E-sim works perfectly everywhere I go so I don’t think it’s a problem with how my phone is configured. Even in areas of weak signal I still get some data from the E-sim but none if I switch to EE. T-mobile is one of the networks I can manually select on EE so I can’t see why it wouldn’t work. It has to be a fault with EE - something is blocking my access to data
07-07-2023 07:28 AM
Thanks, @bc43
I'm not sure what could be causing this, it sounds like you've tried everything we'd usually recommend. I know you've already spoken to our technical support team, but I'd recommend doing so again so that this can be looked into.
