21-04-2025 11:28 PM
So I usually use WiFi calling because of poor signal at home however recently the phone has been cut off because of a dispute that ee still need to respond about and since then whenever I make a call with WiFi calling it just diverts to the ee payment system even in aeroplane mode. But any search of the forum seems adamant that ee don't block WiFi calling, seems pretty certain they do seeing as I am now left unable to make an emergency doctor's appointment because of a situation caused by ee in the first place
22-04-2025 12:08 AM
WiFi-calling uses EE's central network just like mobile-network-based calls, the only difference is not using the radio network.
Thus if your phone has been suspended for whatever reason, then all network access is affected.
22-04-2025 09:48 AM
It sounds like the call itself is being blocked, regardless of whether it's on WiFi. You'll normally only be diverted to the payment system like that if there's a balance that needs to be paid
