Edge
IW6
I am in Berlin and my sons EE iphone is just saying Edge and he has no connection. Any ideas?
Jon_K
Former EE Employee
Hi @IW6
Can you try restarting the phone?
What phone is he using?
Jon
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Northerner
Hi @IW6
Try manually selecting another network.
