EU Roaming
SeemaPabs
I didn’t text ROAM EU to 150 before I left for my holiday and now can not as I have no access to carrier services. Is there any other way I can activate roaming?
@SeemaPabs : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
