on 23-11-2022 03:40 PM
For weeks now my EE wifi calls while working from home are failing! Constant "drop-out" on calls are affecting my customers, and I'm getting angry feedback. Also, when my wife also works from home, she has the same problem with both her work-supplied phone, and her personal mobile. There is a serious problem with the EE wifi call system, and when I tried to get on the EE website on my mobile, there was a problem there today (23.11.22) at 15.40pm
on 23-11-2022 04:41 PM
on 26-11-2022 06:15 PM
on 27-11-2022 08:45 AM
on 27-11-2022 01:09 PM
Hi Christopher.
Yes, I do still have the EE router, though with the WiFi turned off. It is operating as a modem to my Google Nest router,
The same problem persists if I disconnect the Google router, and restore the EE WiFi. I am convinced either I have a faulty BT Router/modem (unlikely), or the issue, which many others are having, is to do with the roll-out of the digitalisation of the BT telephone exchanges.....
on 27-11-2022 01:15 PM
Hi Leanne T
A BTB Hub6. Which has performed well for over 2 years, until the local BT Exchange was changed to fully fibre this year. The Exchange is only 250 metres from my property, the Green cabinet is only 50 metres from my property, and the telephone pole from where the copper cable runs to connect to my property, is only 20 metres.
on 27-11-2022 01:30 PM
OK, thanks @crumbly78
It may be worth speaking to our technical support team so they can help with this.
on 27-11-2022 01:34 PM
Your phone's screen will have an indicator next to the signal bars which shows whether you're using "VoLTE" (4G-calling) or "WiFi-calling".
Which is displayed when your calls drop? VoWiFi will generally only kick in when your mobile service is minimal or zero.
Is your broadband connection stable for other purposes?
on 27-11-2022 02:11 PM
Hi Guys.
Thank you for your replies.
Just to be clear. We are 22 miles from the financial centre of the UK, and yet have absolutely NO mobile signal at all. That is across all the mobile network providers.
The ONLY way our mobile phones work at home is through the EE WiFi Call system.
As I am typing these replies, I am getting a red banner flash up for a few seconds apologising for being unable to complete the action, indicating drop-outs.
Our phones show we are connected to wifi and to the internet, our other devices connect to the internet ok, and we can view content with no problem. Occasionally, my Sony smart TV will flash a message for a few seconds (just as my laptop does as I'm typing this) indicating that internet connection is lost, but not long enough to interrupt a programme.
But the "EE wifi call" banner does not now display on our phones at all, and hasn't for some time. It used to work perfectly. I've tried all the standard resets. Resetting the router, restarting our iPhones, disconnecting my Google router and restoring the BT router's WiFi. Nothing makes any difference. If we try to make calls, we cannot be heard by the other party, or we are cut off at our end. Calls made to our mobiles result in the caller being told our phones are unavailable.
I have spoken on our landline to EE technical support, who have referred me to BT. I have spoken with BT technical support, carried their recommended tests under their supervision, all to no avail. BT say the broadband is working fine, EE have not been of any help at all so far. I have no idea what the problem is, only that I am paying EE for a mobile phone service that does not work at home.
I'm considering contacting the CEO's of BT and EE, and OffCom, as this situation is completely unacceptable in today's internet-driven environment.
on 27-11-2022 02:53 PM
Thanks for giving us some information about this, @crumbly78.
I've sent you a private message to try and get you some help with this.
