EE not working abroad
00363867
Hi, I travel quite often but I am based in the UK.
This morning my mobile is not working and seems like the EE connection being deactivated.
The second SIm works fine.
Any help to whom to contact would be really appreciated.
Francesco
@00363867 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
-thank you for your reply. I am on pay as you go but have a recurring
monthly payment.Yes I used my mobile as usual last week and all the
weekend this worked on my EE network. It is just since this morning is no
longer connected for calls & data.
I think I tried all the settings I could, including selecting manual
networks (all access are denied from local providers it says).
Thanks anyway for the help
Francesco
Christopher_G
Hi @00363867
Whereabouts in the world are you at the moment?
Have you tried manually connecting to different networks?
