EE data problem in Gibraltar
Shreedhar_ee55
Hy there I am in Gibraltar at the moment and I already have a monthly contract for 24 months but my mobile data is not working here can you help me out?
@Shreedhar_ee55 : Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Apart from the advice already posted, does your phone have signal indicators from a local network?
Knowing that will help establish whether this is a problem specifically with mobile data, or with your roaming facility in general.
Yes I can see the local network saying Gibtel
James_B
EE Community Manager
Hi @Shreedhar_ee55,
Did you check the roaming settings in My EE that @XRaySpeX mentioned?
