14-04-2022 09:06 PM
I have unlimited data as part of my EE package. However, I will be traveling to Cyprus tomorrow (which is in the EU) and I can't find if my unlimited data also continues there?
14-04-2022 09:44 PM
@Rachel1410 You can only use 50Gb of data per month when roaming. Please have a look at THIS because depending on when you took out that contract you might need to purchase a add on to use that data.
14-04-2022 10:01 PM
Hi @Rachel1410
Just to add North Cyprus is classed as Turkey and not part of the EU. You need to be careful as your device may connect to the Turkish network if you're close to the border. You can minimise this problem by turning off auto network selection under network settings. If you're nowhere near the border or don't care don't worry about it.
