Data
danadohertyx
I am currently in Belgium and my data isn’t working even though I have unlimited data and other people that use ee are able to use theres. I am away with my school and have to keep my pe rents updated so if you could solve my problem or tell me why it isn’t working it would be appreciated
@danadohertyx : Can't you make calls & texts? You don't need any data to just call or text your parents.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
Does your phone show signal indicators of a local network in Belgium?
That would decide whether this is a problem with your roaming funtionality (as advised to resolve above), or potentially a data-specific issue.
