Data roaming won't work in Morocco
Dev365494
I have the 'roam abroad pass' which has worked all over Europe this summer.
However since I have been in Morocco have had no data at all.
Roaming is switched on.
Any ideas?
@Dev365494 : Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
