on 10-08-2022 03:51 PM
Data roaming not working aboard - working fine on one iPhone 11 but not the other iPhone 11??
on 10-08-2022 04:05 PM
@Icgooner : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
