Data abroad
Helenedim
Hi , I moved to Greece for holidays and it seems that I can not make calls or use my data for internet use
Christopher_G
Hi @Helenedim
Welcome to the community.
Is your SIM card pay monthly contract or pay as you go?
Does your phone find a Greek network provider?
@Helenedim : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
