09-10-2022 04:08 PM
I’m not getting any service or data whilst abroad despite that being part of my plan. Please can you help
09-10-2022 04:31 PM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
09-10-2022 04:33 PM
If you're pay monthly try activating roaming on your EE .
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Click on the person icon in the corner - Settings and Permissions - activate roaming abroad
