Currently Abroad and can't Activate Roaming
mosanha
Im currently in Portugal and I thought would automatically activate Roaming - well, it doesn't. My bad for not checking.
Im in Portugal and cant activate Roaming neither by texting ''Roaming'' to 150 or through my online EE account - My device is a Redmi Note 10 Pro - What should I do?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything.
