Cant use roaming
Samdaman93
Hello,
I flew into UK, bought a sim then that same day flew to Greece. I'm only in Europe for a month but need roaming to use data to find my way.
I thought the lady called herself when I bought the Sim, but from searching online it seems that maybe the Sim wasn't properly activated before I went? I can't make calls, can't text, can't use data. I've setup my EE account but can't find roaming options.
How do I get this working? Or have I wasted money buying this then immediately leaving the UK.
Cheers,
Northerner
Hi @Samdaman93
If the SIM wasn't activated in the UK it won't work. No solution unless you come back to the UK to activate.
Christopher_G
Hi @Samdaman93
Welcome to the community.
Is it a pay as you go SIM card? If so, and that call wasn't made, the SIM won't be activated for roaming abroad until you're back in the UK.
Northerner
Hi @Samdaman93
